• Tech Tips
  • Tech Tips
Updates To Vizible: Parenting Assets, Copying Assets, New Avatars, And More
Vizible is our VR creation and collaboration tool that lets people easily create immersive VR experiences and experience them with people around the world for real time communication and collaboration in virtual reality. We're making improvements t [...]
Read More
November Tech Tip: Recording & Embedding Avatars In VR Presentations with Vizible
At WorldViz, we make tools that help a wide variety of professionals create immersive VR experiences that can be experienced collaboratively. Our VR collaboration solution Vizible (try it here), has a unique feature that we want to highlight in this [...]
Read More
October Tech Tip: Bringing Spherical Videos Into Vizible VR Presentations
WorldViz is creating a next-generation VR creation and collaboration solution, Vizible. If you’d like to apply for the beta and try it today, you can sign up here. When designing 3D/VR environments, we think you should be able to bring a wide arra [...]
Read More
September Tech Tip: Skydomes and the Background Map Export Setting
Ever wondered how to achieve that perfect view out of your virtual windows? Read this article in our knowledge base to learn more about Skydomes, where to find them/how to create them and how the OSG exporter can help you to get the best out of your [...]
Read More
August Tech Tip: SketchUp to Vizard workflow
SketchUp is a great tool for quickly creating and modifying existing 3D content for Vizard and WorldViz's new remote collaboration platform, Vizible. With its extensive libraries of VR commands, Vizard makes it possible to transform a SketchUp mo [...]
Read More
February Tech Tip: Vizconnect Viewpoint Collision
Vizconnect's viewpoint collision is used to stop the user's avatar and viewpoint from moving through other objects in the scene. It is designed to create a seamless collision effect when combining trackers, transports, custom navigation nodes, and an [...]
Read More
December Tech Tip: Alpha-to-Coverage
When rendering with alpha the final image is a blending of two or more objects. Depending on the combination of alpha objects and their placement, issues can arise with the final blended image. [...] [...]
Read More
August Tech Tip: Point Cloud Formats
Vizard supports point clouds models with .3dc, .asc, and .ply file extensions and the DotProduct3D scanner cloud format (.dp). If you have a text file with a different extension and the data is in XYZ format, rename the extension to .3dc and then lo [...]
Read More
July Tech Tip: Sound Mixer
  Use the Vizard sound mixer library to apply volume, pitch, and filter effects to global (non-spatialized) sounds. The mixer supports playing single and multi channel WAV files. The following code adds a sound mixer and plays a sound. Run [...]
Read More
June Tech Tip: Using the Demo Launcher
The WorldViz demo launcher is a tool for downloading and running Vizard demo applications. It is designed to run on any virtual reality hardware. The demo launcher opens up two windows: Vizard graphics window: This is the window that renders [...]
Read More
