Integrating Lab Streaming Layer (LSL) with SightLab VR Pro
August 8, 2025
Lab Streaming Layer (LSL) is an open-source middleware ecosystem designed to stream, receive, synchronize, and record neural, physiological, and behavioral data across diverse sensor hardware. By bridging LSL with SightLab VR, researchers can seamlessly incorporate third-party EEG, eye-tracking, and physiological data into their virtual reality experiments, as well as export VR-derived metrics to external acquisition software.
For more information see this page
Overview of LSL
LSL provides a unified interface for real-time data transmission:
  • Networked Streams: Transmit data packets over IP, allowing multiple applications on the same or different machines to share time-synchronized streams.
  • Cross-Platform: Supports Windows, macOS, Linux, iOS, and Android.
  • Broad Device Support: Hundreds of biosignal, motion, and other research-grade sensors are LSL-compatible.
For a complete list of supported devices and applications, visit the Lab Streaming Layer device list.
Installing LSL for SightLab
Before integrating LSL with your SightLab project, install the Python bindings:
# In the Vizard IDE: Tools → Package Manager → Add Package
pip install pylsl
Then, in your script’s imports:
from pylsl import StreamInlet, StreamOutlet, resolve_stream
Streaming Into SightLab (Stream Inlet)
To ingest external biosignals (e.g., EEG from Muse or BrainVision) directly into your VR session:
Discover the Stream
# Wait up to 5 seconds for an EEG stream
streams = resolve_stream('type', 'EEG')
inlet  = StreamInlet(streams[0])
  1. Add Stream to SightLab Recorder
    sightlab = sl.SightLab()
sightlab.addStreamInlet('EEG', inlet)
  1. Save to Data Files
    SightLab will automatically timestamp and include incoming samples in its recording CSVs and experiment summary.
See ExampleScripts/LSL_Sample/lsl_sample_receive.py for a complete implementation, including averaging and experiment-summary integration.
Streaming Out of SightLab (Stream Outlet)
Export VR-derived metrics—such as gaze coordinates, head orientation, or pupil diameter—to external analysis tools:
Create an LSL Outlet
from pylsl import StreamInfo, StreamOutlet
info   = StreamInfo('SightLabGaze', 'Gaze', 3, 0.0, 'float32', 'sightlab123')
outlet = StreamOutlet(info)
sightlab.addStreamOutlet('Gaze', outlet)
  1. Push Data During Trials
    Inside your trial loop or callback:
    gaze_pos = sightlab.getCurrentGazePosition()  # [x, y, z]
outlet.push_sample(gaze_pos)
  1. Use in External Software
    Common applications include:
    • BioPac AcqKnowledge
    • MATLAB (via LSL MATLAB API)
    • BrainVision Recorder
See ExampleScripts/LSL_Sample/lsl_sample_stream.py for generic outlet setup.
Workflow: SightLab → Biopac AcqKnowledge
AcqKnowledge now natively supports LSL enabling VR-derived streams to be captured alongside physiological channels.
  1. Enable LSL in AcqKnowledge
    • Display → Preferences → Hardware → Data Acquisition
    • Check “LSL” as a hardware source.
  2. Add LSL Stream
    • In your graph window, click “+” → LSL.
    • Restart AcqKnowledge to refresh hardware options.
  3. Connect to SightLab Outlet
    • In a new experiment (File → New), select LSL from the hardware dropdown.
    • Press “Refresh” when your SightLab script is running.
  4. Visualize & Record
    • VR metrics (e.g., gaze path, pupil size) appear as channels in AcqKnowledge.
Troubleshooting Tips
  • “No Stream Available” upon launch?
    • Start your SightLab script to open the LSL outlet.
    • Hit “Refresh” in AcqKnowledge’s hardware menu.
  • Outlet Unexpectedly Closes
    • If SightLab exits or the outlet is closed, go to “Manage Hardware Connections” in AcqKnowledge to rediscover streams.
  • Latency Concerns
    • Ensure both applications are on the same LAN and that firewall settings permit UDP traffic on the LSL port range (default: 11000–11999).
Conclusion
By leveraging LSL within SightLab, researchers gain a versatile pipeline for incorporating and exporting rich, synchronized biosignal and behavioral data. Whether streaming in EEG for closed-loop VR paradigms or pushing gaze and kinematic metrics to Biopac AcqKnowledge, the integration empowers complex, multimodal experiments with precise timing and minimal overhead.
