How to Connect the Vive Focus Vision Face Tracker to SightLab for Vizard and Use It in Your VR Research
April 13, 2026
The HTC Vive Focus Vision is a powerful standalone OpenXR headset that supports eye tracking, hand tracking, stereo passthrough — and with the Face Tracker add-on, full lower-face expression tracking. When integrated with SightLab, you can record and analyze facial expressions alongside gaze, head position, hand tracking, and experimental events.
For more information see this page https://help.worldviz.com/sightlab/face-tracking/
This guide walks you through:
  1. Hardware setup
  2. Streaming & OpenXR configuration
  3. Enabling face tracking in SightLab
  4. Logging and saving facial expression data
  5. Practical research use cases
1️⃣ Hardware Setup – Attaching the Face Tracker
https://m.media-amazon.com/images/I/51w307D8INL.jpg
https://www.ino-vr.com/librairie/Redimensionne_image/resizer.php?decode=0&imgfile=photos_site%2Fimg_article%2F1684855752vive-focus-3-facial-tracker-back.jpeg&max_height=500&max_width=500
Attach the Face Tracker Module
  1. Remove the front compartment cover of the headset.
  2. Attach the VIVE Facial Tracker module.
  3. Plug the USB-C cable into the internal USB port.
  4. Secure the cable and replace the cover.
  5. Power on the headset.
  6. In headset settings, enable facial tracking.
Important Notes
  • Without the face tracker add-on:
    You get upper-face tracking only (eyes, brows).
  • With the face tracker add-on installed:
    You get lower-face tracking (mouth, lips, cheeks, jaw, tongue).
2️⃣ Connect Vive Focus Vision to Your PC (OpenXR Required)
SightLab uses OpenXR for face tracking access.
According to the Vive Focus Vision setup documentation , you must:
Install Required Software
  1. Install Steam
  2. Install SteamVR
  3. Set SteamVR as the default OpenXR runtime
  4. Install Vive Business Streaming
  5. In Vive Business Streaming:
    • Register OpenXR
    • Enable eye + face tracking
    • Adjust bitrate (lower for WiFi)
Wired vs Wireless
  • ✅ Wired (USB-C 3.0) – Recommended for research stability
  • ⚠ Wireless requires strong Wi-Fi 6/6E
3️⃣ Select Vive Focus Vision in SightLab
In SightLab GUI:
  • Open SightLab VR
  • Select “Vive Focus Vision” from headset dropdown
You can see in the configuration file that this maps to:
'Vive Focus Vision':'vizconnect_config_focus_vision_openxr.py'
(from settings.py )
This ensures:
  • OpenXR pipeline is active
  • Eye + face tracking extensions are enabled
4️⃣ Adding Face Tracking to a SightLab Script
SightLab provides two modules:
For Meta Headsets:
from sightlab_utils import face_tracker_data
For HTC Headsets (Vive Focus Vision):
from sightlab_utils import face_tracker_data_htc
The HTC module is required for Vive Focus Vision.
Minimal Working Example (HTC)
import viztask
sightlab = sl.SightLab()
# Initialize face tracking
face_tracker_data_htc.setup()
def sightLabExperiment():
   yield viztask.waitEvent(EXPERIMENT_START)
   while True:
       # Continuously update facial tracking
       vizact.ontimer(0, face_tracker_data_htc.UpdateAvatarFace)
       yield sightlab.startTrial(
           startTrialText="Make facial expressions.\n\nPress Trigger to Start"
       yield viztask.waitKeyDown(" ")
       yield sightlab.endTrial()
viztask.schedule(sightlab.runExperiment)
viztask.schedule(sightLabExperiment)
viz.callback(viz.getEventID('ResetPosition'), sightlab.resetViewPoint)
What This Does
  • Activates face tracking
  • Streams real-time expression values
  • Saves data automatically to the /data folder
  • Logs values per trial
5️⃣ What Facial Data Is Recorded?
The HTC Vive Face Tracker provides two groups of parameters:
👁 Eye Expressions (Upper Face)
EYE_LEFT_BLINK
EYE_RIGHT_BLINK
EYE_LEFT_WIDE
EYE_RIGHT_WIDE
EYE_LEFT_SQUEEZE
EYE_RIGHT_SQUEEZE
👄 Lower Face Expressions (With Add-On Installed)
LIP_JAW_OPEN
LIP_JAW_FORWARD
LIP_MOUTH_SMILE_LEFT
LIP_MOUTH_SMILE_RIGHT
LIP_CHEEK_PUFF_LEFT
LIP_CHEEK_PUFF_RIGHT
LIP_TONGUE_UP
LIP_TONGUE_DOWN
Each value is typically normalized between 0–1.
These values are:
  • Logged per frame
  • Timestamped
  • Saved to trial_data.csv
  • Usable for replay visualization
6️⃣ Built-In Face Tracking Example Templates
From the ExampleScripts folder :
📌 Mirror Demo
Maps your facial expressions to an avatar.
📌 FaceTracker_Sliders
Expression values drive real-time GUI sliders.
📌 Facial_Expressions_Over_Time
Plots expression values using matplotlib.
📌 Face_Tracking_Saving_HTC
Saves facial tracking values per trial.
7️⃣ How Face Tracking Is Used in Research
Here’s how researchers commonly use Vive Focus Vision face tracking in SightLab:
🧠 Emotional Response Studies
Measure:
  • Smile intensity
  • Brow furrowing
  • Jaw tension
  • Cheek puff
During:
  • Stimulus exposure
  • VR therapy
  • Marketing simulations
🎓 Educational VR
Track:
  • Engagement via eye widening
  • Confusion via brow lowering
  • Reaction to feedback
Combine with:
  • Gaze tracking
  • Dwell time
  • Performance metrics
🤖 AI Agent Interaction
Facial data can enhance AI avatar systems (see AI Agent docs ):
  • Mirror participant emotion
  • Adapt dialogue tone
  • Trigger contextual responses
🧪 Cognitive Load Experiments
Combine:
  • Eye openness
  • Blink rate
  • Jaw clench
  • Fixation metrics
For multimodal stress analysis.
8️⃣ Data Storage & Replay
Face tracking values are:
  • Saved in /data
  • Included in trial replay
  • Synchronizable with:
    • Eye tracking
    • Head position
    • Hand tracking
    • Grab events
    • ROI viewing
You can replay sessions using the built-in replay tools.
9️⃣ Best Practices for Reliable Data
✔ Use Wired Connection
Reduces dropped frames.
✔ Confirm OpenXR is Registered
Must be enabled in Vive Business Streaming.
✔ Use Test Script First
Validate tracking before running full experiment.
✔ Use GUI + Code Hybrid Workflow
Configure trials in GUI, extend with Python.
🔟 Summary
To use the Vive Focus Vision Face Tracker with SightLab:
  1. Physically attach face tracker module
  2. Enable face tracking in headset
  3. Install SteamVR + Vive Business Streaming
  4. Register OpenXR
  5. Select Vive Focus Vision in SightLab
  6. Import face_tracker_data_htc
  7. Call UpdateAvatarFace() on timer
  8. Run experiment — data saves automatically
You now have full multimodal behavioral data collection:
  • 👁 Eye tracking
  • 👄 Facial expression tracking
  • 🖐 Hand tracking
  • 📍 Head position
  • 🎯 Gaze object interaction
All synchronized inside SightLab.
To see how you can use face tracking in your research with SightLab and Vizard contact sales@worldviz.com
To request a demo of SightLab click here https://help.worldviz.com/sightlab/
