How to Display VR Sessions on a PRISM Immersive Theater or Projection VR
January 23, 2026
This guide explains how to display live VR sessions on a PRISM immersive theater or projection-based VR system. It covers both multi-user observer views and single-user projection setups, including keyboard navigation and advanced 3D projection configuration.
Overview: Display Options for Projection Systems
When running a VR session, there are two primary ways to display the experience on a PRISM or projection wall:
  • Observer (Bird’s-Eye) View
    A free-flying camera used to observe one or more users from outside their perspective.
  • First-Person View
    Displays exactly what a participant sees (single user or selected client).
Both options can be run on a standard desktop system connected to a projection or PRISM display.
Running a Bird’s-Eye / Observer View (Multi-User)
The observer view is ideal for:
  • Classroom demonstrations
  • Research observation
  • Public presentations
  • Multi-user experiment monitoring
Step-by-Step Setup
  1. Start the Server
    • Launch the SightLab Server or E-Learning Lab Instructor
  1. Start Participant Clients
    • Run the appropriate number of client scripts for your VR users.
  1. Launch an Additional Client for PRISM / Projection
    • On the computer driving the PRISM or projection system, run one additional client.
    • This client connects to the same server but is used only for display.
  2. Select the Client Environment
    • Recommended options:
      • Empty – if you want no visible avatar or interaction
      • Security Camera – if you want a visible camera object inside the scene
  1. Choose Hardware Type
    • Select Desktop as the hardware option.
Navigating the Observer View
Once the scene starts, you can control the observer camera using the keyboard:
Movement & Rotation
  • W / A / S / D – Move forward, left, backward, right
  • Z / X – Move down / up
  • Q / E – Rotate left / right
Utility Controls
  • R – Reset viewpoint
  • Shift – Lock/unlock movement
  • / – Take a screenshot
  • . (Period) – Toggle overlays (timers, view counts, trial info)
  • F2 – Toggle fullscreen mode
Note: Fullscreen may apply to only one monitor. For PRISM systems, you can manually stretch the window across all displays to span the full wall.
Alternative Observer Controls (Server on Projection Machine)
If the server itself is running on the PRISM / projection computer, the following controls may be used instead:
  • U / J – Forward / backward
  • H / K – Left / right
  • N / B – Up / down
  • Y / I – Yaw left / right
  • O / L – Pitch up / down
Running a First Person/ Single-User Projection View
For single-user scenarios (no server/client architecture):
  1. Run a SightLab or E-Learning Lab client
  2. Choose Desktop as the hardware type
  3. Connect the output to the PRISM or projection system
This mode mirrors the participant’s first-person view directly onto the projection display.
Running a 3D Projection Wall (Advanced Setup)
To run stereo or multi-display projection systems, you must use a custom vizconnect configuration.
E-Learning Lab Configuration
Open the globalConfig file
Set:  LOCAL_VIZCONNECT = True
Navigate to:  local_vizconnects/vizconnect_config_projection.py
Modify the displays section to match your projector layout and resolution
SightLab Configuration
Navigate to: C:\Program Files\WorldViz\Vizard8\bin\lib\site-packages\sightlab_utils\vizconnect_configs\vizconnect_config_projection.py
Paste it into a new folder named: local_vizconnects
Initialize SightLab using the custom config:
sightlab = sl.SightLab(vizconnectconfig={'Projection': 'vizconnect_config_projection.py'})
Modify the displays section in the config file to match your projection hardware
Best Practices & Tips
  • Use Observer Mode for teaching, demos, and research monitoring
  • Use First-Person Mode for immersive presentations
  • Disable overlays (. key) for clean public displays
  • Test fullscreen behavior before live demos
  • For large PRISM systems, ensure GPU output alignment matches projector mapping
Need Help Designing a VR Lab?
PRISM, Projection VR, Multi-User SightLab, and E-Learning Lab can be combined in many configurations depending on your space and goals.
For advanced setups or system design guidance, contact:
📧 sales@worldviz.com
