3D Model Workflows into Vizard
September 28, 2022
Sado Rabaudi
Importing from various 3D model programs and sources into Vizard is a great way to get existing content into your Vizard application. Here is a quick overview of the suggested workflows from some common programs and sources. For more information, please see the Vizard documentation section on 3D models.
PBR and GLTF
Our most up to date Vizard workflow focuses on Physical Based Rendering (PBR), especially through the use of GLTF format (.gltf, .glb) which imports with PBR materials automatically. Other file formats currently require additional setup to use PBR.
Export Options
‍CAD / Architecture Modeling Software
Revit (Extension - .rvt)
  • Export options: Simlabs, Sketchfab Exporter, native FBX export, PIXYZ
  • Suggested workflow: GLTF via PIXYZ‍
  • Note: Sketchfab exporter requires Revit 2018.1 and above
SketchUp (Extension - .skp)
Rhino
Solidworks
  • Suggested workflow: GLTF via Simlabs
Polygon Modeling Software
3DSMax (Extension - .max)
  • Export options: Bablyon.js, Sketchfab exporter
  • Suggested workflow: GLTF via Babylon.js
Blender (Extension - .blend)
  • Export options: gltF exporter
  • Suggested workflow: Built in glTF exporter
Maya (Extension - .ma)
  • Export options: Babylon.js, Sketchfab exporter, Ziriax
Modo (Extension - .lxo)
  • Export options: Native
  • Suggested workflow: Native GLTF exporter
  • Note: You must setup your materials for gltf in Modo first
Miscellaneous
Substance Painter (Extension - .spp)
  • Export options: Native GLTF exporter
Sketchfab
  • Export options: glTF, FBX exporter
  • Suggested workflow: GLTF download option. See Sketchfab to Vizard
ZBrush
  • Export options: FBX exporter
  • Suggested workflow: Best used in a “high poly to low poly” workflow by an expert user
Unity
  • Suggested workflow: FBX exporter
*Note: Can convert to glTF after export can use an online tool
Point Clouds
For information on how to bring point cloud data into Vizard, please see this knowledge base article.
Avatars
Avatar models can be brought in if they are in either the .fbx, .glTF or .cfg (cal3D) format. See this article for information on bringing in avatar models into Vizard.
We hope you liked this quick overview of bringing in 3D models into Vizard. Other content from additional sources will work as well if the format is one of the supported file types, preferably .glTF or .fbx.
You can also bring in content such as 360 videos (stereoscopic and monoscopic), 2D videos, images, audio (3D and stereo), and more.
To see how you can import your existing content and get started using Vizard for your own VR application, please contact us at
