Creating and Customizing an AI Agent in SightLab VR Pro
June 11, 2026
SightLab GUI avatar workflow settings
SightLab’s AI Agent workflow makes it possible to add interactive, intelligent virtual characters into VR and XR simulations. These agents can use large language models such as OpenAI, Anthropic Claude, Gemini, or offline Ollama models, and can be paired with custom avatars, voices, personalities, animations, speech recognition, and even event-based behaviors.
This guide walks through the recommended workflow for setting up, customizing, and running an AI Agent in SightLab.
See this page for more information.
Additionally, for adding instructional AI tutors and agents in the E-Learning Lab see this page.
What You Can Do with the AI Agent
The AI Agent can be used to create virtual humans, tutors, guides, interviewers, simulation partners, or interactive characters inside a SightLab project.
Key capabilities include:
Feature Description
Multiple LLM Options Use OpenAI, Anthropic, Gemini, or offline Ollama models such as Llama, Gemma, Mistral, and DeepSeek
Custom Avatars Works with RocketBox, Mixamo, ReadyPlayerMe, Avaturn, Reallusion, and other avatar libraries
Voice Interaction Speak to the agent using speech recognition or type text input
Text-to-Speech Supports Edge-TTS, Kokoro, Piper, OpenAI TTS, ElevenLabs, and PYTTSX3
Custom Personality Define the agent’s role, personality, emotional style, and context using prompt files
Event System Trigger expressions, animations, screenshots, or custom callbacks from the AI’s response
SightLab Integration Use SightLab data collection, replay, visualizations, and transcript saving
Quick Start
To try the AI Agent with the default setup:
  1. Open the AI Agent folder.
  2. Run AI_Agent_GUI.py to use the GUI workflow, or run AI_Agent.py for the non-GUI version.
  3. Select your environment, hardware, AI model, voice, and agent options.
  4. Press Continue.
  5. Press Spacebar to start the scene
  6. Hold the c key or the right-hand grip button to speak.
  7. Release the button to let the agent respond.
Tip: Run multi_agent_interaction.py to see an example with two AI agents talking to each other.
Setting API Keys
Online models require API keys. Offline Ollama models do not require keys.
The recommended method is to set API keys as Windows environment variables. Open Command Prompt and run:
setx OPENAI_API_KEY your-api-key
setx ANTHROPIC_API_KEY your-api-key
setx GEMINI_API_KEY your-api-key
setx ELEVENLABS_API_KEY your-api-key
After setting the keys, restart Vizard.
You can also input your keys in the SightLab Dashboard settings, or simply place them in the ‘keys’ folder in the AI_Intelligent_Agent main folder named as openai_api_key.txt, gemini_api_key.txt, eleven_labs_api_key.txt and gemini_api_key.txt.
Use these services to obtain keys:
Service Where to Get the Key
OpenAI OpenAI platform API keys page
Anthropic Anthropic console
Gemini Google AI Studio
ElevenLabs ElevenLabs developer API keys page
For offline models, install or launch Ollama and run a model from Command Prompt, for example:
ollama run gemma
The first launch may take longer while the model loads.
Creating a Custom AI Agent
The custom agent workflow has three main parts:
  1. Create a prompt.
  2. Create an avatar configuration.
  3. Add the avatar to your scene.
Step 1: Create a Custom Prompt
The prompt defines the agent’s personality, knowledge, role, and behavior.
  1. Open the prompts folder.
  2. Make a copy of default.txt.
  3. Rename it, for example:
MuseumGuide.txt
  1. Edit the prompt to describe the agent’s role.
Example prompt structure:
You are a friendly museum guide inside a virtual art gallery.
You explain paintings clearly and conversationally.
You ask participants reflective questions about what they notice.
Keep responses concise unless the user asks for more detail.
Step 2: Create an Avatar Config
Each avatar uses a config file to control animations, voices, language, morph targets, and other avatar-specific settings.
  1. Open the configs folder.
  2. Copy either:
Template_Male.py
or
Template_Female.py
  1. Rename the file, for example:
MuseumGuideAvatar.py
  1. Open the avatar in Inspector.
  2. Check the animation list in the lower-left Animations panel.
  3. Note the animation state numbers for idle and talking.
  4. In your avatar config file, update:
TALK_ANIMATION = 2
IDLE_ANIMATION = 1
The exact numbers depend on the avatar.
You can also adjust the voice, language, blinking, mouth morphing, head turning, facial expressions, and other settings in the config file.
Step 3: Add the Avatar to Your Scene
The easiest method is to place the avatar directly into your environment using Inspector.
GUI Workflow
  1. Run AI_Agent_GUI.py.
  2. Choose an included environment or drag in a new one.
  3. Click Edit in the GUI to open the environment in Inspector.
  4. Drag your avatar model into the scene.
  5. Position and rotate the avatar using Inspector’s transform tools.
  6. Make sure the avatar name ends in .cfg. (right click on the name in Inspector and choose “Rename”)
Avatar animation and morph settings in the GUI
For example:
CC2_m001_hipoly_A0_v2.cfg
  1. Save the scene in Inspector.
  2. Return to the SightLab GUI.
  3. Close and restart the script and select your prompt and avatar config from the dropdowns.
  4. Run the scene.
By default, the AI Agent will use the first avatar it detects in the scene when:
USE_SCENE_AVATAR = True
Non-GUI Workflow
For non-GUI use, add the avatar to the scene in Inspector, then set the avatar name in Config_Global.py:
SCENE_AVATAR_NAME = 'CC2_m001_hipoly_A0_v2.cfg'
Then run:
AI_Agent.py
If using a Reallusion avatar, or another avatar that does not auto-detect correctly, load it directly by path in the avatar config:
AVATAR_MODEL = 'Resources/avatars/Reallusion_ActorCore_Male.osgb'
Interaction Controls
Use these controls during runtime:
Control Action
Hold c Speak to the agent
Release c Agent processes the speech and responds
Right-hand grip Speak in VR
Press c when speech recognition is off Type a question
Type q Stop text chat
Press h Send a screenshot to the agent
Ask “What are we looking at?” Agent can interpret the visible scene
If HOLD_KEY_TO_SPEAK is set to False, the agent listens continuously and responds after a pause. This mode works best when the user is wearing headphones.
Enabling Passthrough / Augmented Reality
To use the AI Agent in passthrough AR mode, open Config_Global.py and set:
USE_PASSTHROUGH = True
This is supported on compatible headsets such as Meta Quest Pro, Meta Quest 3, Vive Focus Vision, Pimax and Varjo headsets.
Using the AI Agent Event System
The event system allows the AI to trigger actions during a conversation. For example, the agent can smile, look sad, nod, shake its head, or run a custom callback.
How It Works
The AI includes a hidden event line in its response:
event: smile
The system detects the event, runs the corresponding handler, and removes the event line before showing the text to the user.
Example:
User says:
I just won the lottery!
AI raw response:
event: smile
That's incredible! Congratulations! You must be so excited!
The user only sees:
Meanwhile, the avatar smiles.
Enable the Event System
In Config_Global.py:
USE_EVENT_SYSTEM = True
EVENT_KEYWORD = "event:"
Facial expression settings can also be configured:
SMILE_MORPH_ID = 3
SAD_MORPH_ID = 2
EXPRESSION_MORPH_AMOUNT = 0.7
EXPRESSION_DURATION = 1.2
Morph IDs are avatar-specific. To find them:
  2. Select the avatar in the scene graph.
  3. View the morph IDs in the Properties panel.
  4. Update the avatar config with the correct values.
Built-In Events
Event Action
smile Makes the avatar smile
sad Applies a sad expression
neutral Resets facial expression
nod Makes the avatar nod
shake head Makes the avatar shake its head
screenshot Captures and processes a screenshot of the scene
Creating a Custom Event
You can add your own events in AI_Agent_Avatar.py.
Step 1: Create the Event Handler
def event_my_custom_action():
   """Run a custom AI-triggered action."""
   try:
       print("Custom action executed!")
       # Example actions:
       # avatar.state(MY_ANIMATION)
       # object.setPosition([0, 1.5, 1.5])
       # viz.playSound('sound.wav')
       # viz.clearcolor(viz.RED)
   except Exception as e:
       print(f"Error in custom event: {e}")
Step 2: Register the Event
Add the event to register_default_events():
def register_default_events():
   """Register all built-in event handlers."""
   if USE_EVENT_SYSTEM:
       EVENT_REGISTRY.register("smile", event_smile)
       EVENT_REGISTRY.register("sad", event_sad)
       EVENT_REGISTRY.register("neutral", event_neutral)
       EVENT_REGISTRY.register("my_custom_action", event_my_custom_action)
Step 3: Add the Event to the Prompt
Tell the AI when to use the event:
Available events:
- smile: Use when responding happily or positively.
- sad: Use when responding with sympathy.
- my_custom_action: Use when the user asks you to demonstrate the custom action.
Multi-Agent Interactions
AI Agent
SightLab also includes a multi-agent example:
This allows two AI agents to speak with each other and respond to the user.
Example setup:
from AI_Agents import AIAgent
agents = [
   AIAgent(
       config_path='configs/x_Multi_RocketBoxFemale.py',
       name='Agent1',
       prompt_path='prompts/Susan_Home Office.txt'
   AIAgent(
       config_path='configs/x_Multi_RocketBoxMale.py',
       name='Agent2',
       prompt_path='prompts/Tom_Home_Office.txt'
Controls:
Control Action
c Speak to Agent 1
v Speak to Agent 2
r Restart the agent conversation
Each agent can use its own config file, prompt, model, and voice.
Adding the AI Agent to an Existing SightLab Script
To integrate the AI Agent into another SightLab project:
  1. Copy these folders/files into your project:
configs
keys
prompts
AI_Agent_Avatar.py
  1. Import the AI Agent configuration:
from configs.AI_Agent_Config import *
import AI_Agent_Avatar
  1. Add the avatar to SightLab:
avatar = AI_Agent_Avatar.avatar
sightlab.addSceneObject('avatar', avatar, avatar=True)
Or, if using an avatar already placed in the scene:
USE_SCENE_AVATAR = AI_Agent_Avatar.USE_SCENE_AVATAR
This allows the AI Agent to work alongside SightLab’s normal experiment features, including data collection, replay, visualizations, and object tracking.
Troubleshooting Tips
Issue Suggested Fix
Microphone does not work Check that the Windows microphone, VR headset microphone, and audio output settings match
ElevenLabs does not play audio Install mpv, add it to the Windows PATH, and restart Vizard
Gemini quota error Try another Gemini model or enable billing for higher limits
Avatar does not animate correctly Check the animation state numbers in Inspector and update the avatar config
Facial expressions do not work Verify the correct morph target IDs in Inspector
Offline model does not respond Make sure Ollama is running and the selected model has been downloaded
Best Practices
Use the GUI workflow when first setting up an AI Agent, especially when testing models, voices, avatars, and prompts.
Use the non-GUI workflow when embedding the AI Agent into a custom SightLab experiment.
Keep prompt files focused and specific. A good prompt should define the agent’s role, tone, knowledge boundaries, and interaction style.
Use events sparingly and clearly. Add event instructions to the prompt so the AI knows when to smile, nod, take a screenshot, or trigger a custom action.
Test avatar animations and morph IDs in Inspector before running a full experiment.
For offline demos, use Ollama and an offline TTS option such as Kokoro or Piper.
Summary
The SightLab AI Agent workflow provides a flexible way to add intelligent, conversational avatars to VR and XR simulations. Using prompts, avatar configs, LLM settings, speech recognition, text-to-speech, and event callbacks, you can build agents that act as instructors, guides, interviewers, collaborators, or interactive characters.
For most users, the recommended workflow is:
  1. Start with AI_Agent_GUI.py.
  2. Choose an environment and hardware setup.
  3. Create or select a prompt.
  4. Create or select an avatar config.
  5. Add the avatar in Inspector.
  6. Choose the model, voice, and speech options.
  7. Run and test the interaction.
  8. Add events or custom behaviors as needed.
For more information on SightLab VR Pro see the documentation here https://help.worldviz.com/sightlab/
Or click here to request a demo
Notes
Add can create custom voices elevenlabs
GPT-Realtime voice (with emotional tone)
Scripted responses (multi-agent, how to do with single user)
E-Learning Lab agents
Point and get information
AI Agent
AI Agent
Download Latest Version
This document describes how to use the AI Agent in SightLab, an interactive, intelligent AI agent that can be connected to various large language models like Chat GPT, Claude, Gemini, Offline Ollama models and more. You can customize the agent's personality, use speech recognition, and leverage high-quality text-to-speech models.
Key Features
Multiple LLM Models OpenAI, Anthropic, Gemini, and hundreds of offline models via Ollama (deepseek, Gemma, Llama, Mistral, etc.) — including vision capabilities
Custom Avatars Modify appearance, animations, and environment. Works with Avaturn, ReadyPlayerMe, Mixamo, Rocketbox, Reallusion, and more
Personality & Context Customize personality, contextual awareness, emotional state, and interactions. Save your creations as custom agents
Voice Interaction Speech recognition to converse using your voice, or text-based input
High-Quality TTS Edge-TTS, Kokoro, Piper, GPT-Realtime, OpenAI TTS, ElevenLabs (requires API), or PYTTSX3
Interactive Events Avatars can trigger custom events — facial expressions, animations, emotional tone (TTS Dependent) and scene interactions based on conversation context
40+ Languages Text to speech models automatically adjust to the selected language
SightLab Integration Data collection, visualizations, transcript saving, and easy addition to any SightLab script
Adaptive Learning The agent adapts using conversation history and interactions
Quick Start
  1. Run AI_Agent_GUI.py to start with the GUI or AI_Agent.py without a GUI
  2. Select your environment, hardware, and options in the GUI and press Continue
  3. Hold the 'c' key or RH grip button to speak; release to let the agent respond
  4. Press 'h' to send a screenshot and ask about what the agent sees (or can just ask "What are we looking at?")
💡 Tip: Run multi_agent_interaction.py for a multi-agent conversation demo.
Setup & Installation
Required Libraries
Ensure you have the required libraries installed using the Vizard Package Manager:
Category Libraries
LLM Providers openai, anthropic, google, google-generativeai, ollama
Speech Recognition SpeechRecognition, faster_whisper, sounddevice
Text-to-Speech edge-tts (samples), kokoro-onnx, soundfile, piper-tts==1.3.0 (samples), elevenlabs, pyttsx3
Other numpy
⚠️ Important: Use piper-tts==1.3.0 — do not update to 1.4.0.
Kokoro has very high quality, low latency and runs offline, but requires downloading the models from here (download and extract into the main/root AI Agent folder)
ElevenLabs Additional Setup
  • For elevenlabs you may need to Install mpv and add to environment variable path (also requires FFMPEG, but this comes with SightLab):
    • Download mpv
    • Unzip and move to C:\Program Files\
    • In Windows search, type powershell, run as administrator
    • Run: setx /M PATH "$($env:PATH);C:\Program Files\mpv-x86_64-20250812-git-211c9cb"
    • Restart Vizard
Offline Models (Ollama)
Ollama comes with the SightLab installer, but if you didn't install it with SightLab, Install Ollama from here, then open a command prompt and type ollama run followed by the model name (e.g., ollama run gemma). See the full model list. The first run may take longer as the model loads.
Note: Requires an active internet connection unless running offline models via Ollama.
API Keys
API keys are needed for online models (OpenAI, Anthropic, Gemini) and optional services (ElevenLabs TTS). For offline models via Ollama, no key is needed.
Setting API Keys (recommended method)
Open a command prompt (type "cmd" in Windows search) and run:
Restart Vizard after setting keys. With this method your API keys are accessible from any folder.
Obtaining Keys
Service Where to Get Key
OpenAI platform.openai.com/api-keys — Set a usage limit if needed
Anthropic console.anthropic.com — Sign up, verify email, generate key
Gemini aistudio.google.com/app/apikey — Also install google and google-generativeai via Package Manager. See Python Quickstart
ElevenLabs elevenlabs.io/app/developers/api-keys — Enable unrestricted access to voices
Customizing Your Agent
Follow these steps to create a custom AI agent with your own personality, avatar, and voice.
Step 1 – Create a Prompt
  1. In the prompts folder, make a copy of default.txt and rename it (e.g., MyAgent.txt)
  2. Write your role-playing instructions for the agent's personality, context, and behavior
  3. You can use an LLM to help create a detailed role-playing prompt
💡 Tip: You can use default.txt as-is if you don't need a custom personality.
Step 2 – Create an Avatar Config
  1. In the configs folder, make a copy of Template_Male.py or Template_Female.py and give it a name (e.g., MyAvatar.py)
  2. Find an avatar — either from the Avatars tab in the SightLab Dashboard Assets library, or drag in from any source (for auto-detection, use RocketBox or Mixamo avatars (requires adding .cfg to the name in Inspector))
  3. Open the avatar in Inspector by double clicking or choosing Open with - Inspector and check the Animations panel (bottom left) — note which animation state number you want for idle and which for talking
  4. In your config file, set:
  5. TALK_ANIMATION — the state number for the talking animation
  6. IDLE_ANIMATION — the state number for the idle animation
  7. Optionally change voices, language, and other settings in the config file (see Avatar Configuration Options for the full list)
Step 3 – Add the Avatar to Your Scene
The simplest way to add an avatar is to drag and drop it directly into your environment in Inspector. The AI Agent will automatically detect and use the first avatar found in the scene (controlled by USE_SCENE_AVATAR = True, which is the default).
Using the GUI (simplest)
  4. Drag and drop your avatar model into the scene
  5. Position the avatar where you want it using the translate and rotate tools (see Adding Avatar Agents for placement tips)
  6. If the avatar's name doesn't end in .cfg, right-click it in Inspector and choose Rename to add .cfg to the end
  1. Go to File → Save in Inspector, then close it
  2. Back in the SightLab GUI, you will see the avatar you added — set the State for the starting idle animation (should match the IDLE_ANIMATION in your config file)
  3. Select your prompt and avatar config from the dropdowns, then run the scene
Without the GUI
  1. Add the avatar to your environment in Inspector as above (steps 4–7)
  2. Set the avatar name in Config_Global.py:
  1. If running from the SightLab Dashboard, click the config action button to directly open the config file
  2. Run AI_Agent.py
Reallusion Avatars
Reallusion avatars need to be loaded by path rather than from the scene. Make a copy of the x_ReallusionMale.py config file, set the path to the avatar directly (this can be done for any avatar that isn't automatically detected as well):
Getting Assets
Refer to this page for instructions on obtaining environments and avatars. Drag new assets into the SightLab Dashboard asset library and then can drag into your project.
For more details on avatar placement, animations, and data collection, see Adding Avatar Agents.
  • Hold 'c' key or RH grip button to speak; release to let the agent respond
  • If USE_SPEECH_RECOGNITION is False, press 'c' to type a question
  • To stop the conversation, type "q" and click "OK" in text chat
  • If HOLD_KEY_TO_SPEAK is False, you only need to speak and when there is a pause of over 0.8 seconds, the agent will respond, then wait for you to speak again (requires wearing headphones)
  • Press 'h' to send a screenshot as a prompt and ask questions about what the AI agent is seeing (in the sub-window), or can just ask "What are we looking at?"
Configuration
Most settings (AI model, voice, language, speech model, etc.) are available as dropdown selections in the GUI. For advanced customization, open Config_Global.py directly — or click the config action button from the SightLab Dashboard.
To enable AR passthrough mode, set this in Config_Global.py:
This works with Meta Quest Pro, Meta Quest 3, and Varjo headsets.
Each avatar uses a config file in the configs folder that controls animations, voice, and behavior. Key settings include TALK_ANIMATION, IDLE_ANIMATION, voice selection, mouth morphing, blinking, and bone/joint references. Make a copy of Template_Male.py or Template_Female.py and adjust as needed — see the comments in the template for all available options. If the avatar doesn't apply things like the head turning to follow you, facial expressions, etc. then you may need to edit these parameters and refer to the avatar in Inspector to see the bone names, etc.
The AI agent supports event-driven interactions, allowing the AI to trigger custom actions during conversations for more expressive and interactive experiences.
The event system allows the AI to execute custom actions (like facial expressions, animations, or any other callback) by including special "event" keywords in its responses. These events are automatically detected, executed, and removed from the text shown to the user.
AI Agent
How It Works
  1. Event Detection: The AI includes event: <event_name> on a line in its response
  2. Event Execution: The system detects this line, triggers the corresponding handler
  3. Text Cleaning: The event line is removed before displaying text to the user
  4. Action: The custom action (e.g., facial expression, processing a screenshot, etc.) is performed
Event Configuration
Global Settings (Config_Global.py)
# Event System Settings
USE_EVENT_SYSTEM = True  # Enable/disable event system
EVENT_KEYWORD = "event:"  # Keyword that triggers events
# Morph Target Indices for Facial Expressions
SMILE_MORPH_ID = 3   # Avatar-specific morph index for smile
SAD_MORPH_ID = 2     # Avatar-specific morph index for sad
EXPRESSION_MORPH_AMOUNT = 0.7  # Intensity (0.0 to 1.0)
EXPRESSION_DURATION = 1.2      # Duration in seconds
Avatar-Specific Settings (configs/RocketBoxMale.py, etc.)
Each avatar config can override the default morph indices:
# Event System - Facial Expression Morph Targets
SMILE_MORPH_ID = 3   # RocketBox smile morph
SAD_MORPH_ID = 2     # RocketBox sad morph
Built-in Events
Facial Expressions
  • smile: Makes avatar smile (uses SMILE_MORPH_ID)
  • sad: Makes avatar look sad (uses SAD_MORPH_ID)
  • neutral: Returns avatar to neutral expression (resets both morphs)
Actions
nod: Nod head in agreement
shake head: shake head side to side in disagreement
Vision
  • Capture and process screenshot of scene: When asked things such as "What do you see" the agent can capture and process a screenshot to give an understanding of its surroundings.
Placeholder Events (for future implementation)
  • wave: Wave animation placeholder
Finding Morph Target Indices for Your Avatar
Different avatars have different morph target indices. To find the correct indices:
  1. Load your avatar in Inspector
  2. Click on the avatar name in the scene graph and view the morph IDs on the right side Properties pane under "Morphs"
  3. Update your avatar config file with the correct indices
Creating Custom Events
Step 1: Create the Event Handler Function
In AI_Agent_Avatar.py, after the existing event handlers:
    """Description of what this event does"""
    try:
        # Your custom code here
        # Examples:
        # - Trigger animations: avatar.state(MY_ANIMATION)
        # - Move objects: object.setPosition([x, y, z])
        # - Play sounds: viz.playSound('sound.wav')
        # - Change lighting: viz.clearcolor(viz.RED)
In the register_default_events() function:
    """Register all built-in event handlers"""
        EVENT_REGISTRY.register("my_custom_action", event_my_custom_action)  # Add this
        # ... rest of the events
Step 3: Update AI Prompt
Add your custom event to the prompt file so the AI knows about it:
Available events you can trigger:
- smile: Makes you smile
- sad: Makes you look sad
- event: screenshot - Take and analyze a screenshot of what you're seeing
- my_custom_action: Description of what it does
Example Prompts
Choose prompts/Event_System_Demo.txt for a comprehensive example prompt that teaches the AI how to use events effectively.
AI Agent
Usage Example
User: "I just won the lottery!"
AI Response (raw):
event: smile
What happens:
  1. Avatar smiles (smile morph applied)
  2. User sees: "That's incredible! Congratulations! You must be so excited!"
Multi Agent Interactions
AI Agent
See the script multi_agent_interaction.py to see how multiple agents can interact and communicate with each other. You can modify the individual agents by calling the AIAgent class and setting parameters such as config_path, name, and prompt_path.
Conversation Modes
The conversation loop can operate in two modes:
  • Scripted Dialogue: Pre-written lines that agents speak in sequence
  • AI-Generated: Dynamic conversation based on a leading question
User Interaction
You can interrupt and speak to either agent during their conversation:
  • Press 'c' to speak to Agent1 (left avatar)
  • Press 'v' to speak to Agent2 (right avatar)
  • Press 'r' to restart the conversation loop
When you interrupt, the agent will turn toward you and stop any current speech. The conversation loop pauses while you interact.
Note that for multi agent interactions, the AI model and voices are defined in the respective config file for each agent (see the configs folder).
Example
agents = [
    AIAgent(config_path='configs/x_Multi_RocketBoxFemale.py', name='Agent1', prompt_path="prompts/Susan_Home Office.txt"),
    AIAgent(config_path='configs/x_Multi_RocketBoxMale.py', name='Agent2', prompt_path="prompts/Tom_Home_Office.txt"),
Adding to Existing Scripts
  1. Copy the "configs", "keys", and "prompts" folders, as well as AI_Agent_Avatar.py.
  2. Import with:
  1. Add avatar:
#Or if using the avatar you place in your scene
  1. Add these lines to enable passthrough augmented reality:
if USE_PASSTHROUGH:
    import openxr
    xr = openxr.getClient()
    if sightlab.getConfig() in ["Meta Quest Pro", "Meta Quest 3"]:
        passthrough = xr.getPassthroughFB()
    elif sightlab.getConfig() == "Varjo":
        passthrough = xr.getPassthroughVarjo()
    viz.clearcolor(viz.BLACK, 0.0)
    if passthrough:
        passthrough.setEnabled(True)
Publishing as an Executable
To publish an application with the AI Agent (or to just publish the standard included template) add this code to the top of the script (before importing SightLab):
# Filter out problematic packages that cause issues in published EXE
viz.res.addPublishFilter('*google_generativeai*')
viz.res.addPublishFilter('*-nspkg.pth')
viz.res.addPublishFilter('*.pth')
# Add publish directories - ensures correct package versions are bundled
publish_directories = [
    'data',
    viz.res.getVizardPath() + 'bin/lib/site-packages/sightlab_utils/',
    viz.res.getVizardPath() + 'bin/lib/site-packages/deepdiff',
    viz.res.getVizardPath() + 'bin/lib/site-packages/numpy',
    viz.res.getVizardPath() + 'bin/lib/site-packages/pandas',
    viz.res.getVizardPath() + 'bin/lib/site-packages/pydantic',
    viz.res.getVizardPath() + 'bin/lib/site-packages/pydantic_core',
    viz.res.getVizardPath() + 'bin/lib/site-packages/openai',
    viz.res.getVizardPath() + 'bin/lib/site-packages/httpx',
    viz.res.getVizardPath() + 'bin/lib/site-packages/httpcore',
    viz.res.getVizardPath() + 'bin/lib/site-packages/anyio',
    viz.res.getVizardPath() + 'bin/lib/site-packages/sniffio',
    viz.res.getVizardPath() + 'bin/lib/site-packages/annotated_types',
    viz.res.getVizardPath() + 'bin/lib/site-packages/certifi',
    viz.res.getVizardPath() + 'bin/lib/site-packages/speech_recognition',
    viz.res.getVizardPath() + 'bin/lib/site-packages/jiter',
for directory in publish_directories:
    viz.res.addPublishDirectory(directory)
Tips & Troubleshooting
Tips
  • Environment Awareness: Press 'h' to take a screenshot that is sent to the agent, or simply ask it "What do you see" or "What are we looking at", etc.
  • Prompts: For configuring the agent, use "I am..." for OpenAI and "You are..." for Anthropic without quotes.
  • Event Trigger for Speech Button: Modify vizconnect to add an event for speaking button hold. Open settings.py in sightlab_utils/vizconnect_configs, and modify mappings for triggerDown and triggerUp or create new ones if needed. More Info on Vizconnect Events
  • If getting an error with Gemini "out of quota", try using a model with more quota or enable billing for much higher limits.
Common Issues
Issue Fix
Microphone/headset conflicts Check that microphone settings match between the VR headset and output device
ElevenLabs character limit Free tier limits to 10,000 characters; paid accounts get more
